D6 FUEL FILTER LEAKING
SHORTORDER
08-05-2007 05:51:37
I have a D6 that all of a sudden started leaking diesel from the fuel filter. I removed the fuel filter top and the fuel filters. The four string filters are dirty and will have to be replaced. The filter top gaskits look good. What would cause the filter to start leaking all of a sudden? Would the dirty filters cause this or is there some type of check valve causing a problem. Thanks for any help.
Shortorder
Bob/Ont
08-05-2007 14:46:09
 Re: D6 FUEL FILTER LEAKING in reply to SHORTORDER, 08-05-2007 05:51:37
Be sure to get all of the dirty fuel out of the housing before putting it back together.
Later Bob
Old Magnet
08-05-2007 09:02:13
I have found that the top gaskets need a sealer (#2 Permatex) to maintain a seal. A slight warpage of the aluminum cover (from over tightening) will also add to the problem.
