1010 CRAWLER
AL
01-05-2002 19:09:39
I have a chance to buy a 1010 crawler with clamshell loader,reverser,diesel engine in very good condition.Were these outfits any good?My
knowledge of crawlers is non-exsisting.Thanks.
Pheastant Hunter
01-09-2002 06:46:44
 Re: 1010 CRAWLER in reply to AL, 01-05-2002 19:09:39
We have a 1010 crawler gas with a 6-way Blade and 3-point.As per the Nebraska Test #801 it will pull 7,179lbs @1.35 mph, with 27.54 hp. The 3010 gas wheel tractor will only do 6,598lbs @2.64 mph with 51.73hp. yes it may not be the fastest, but it is alot of fun.
bryan
01-06-2002 08:57:53
The 1010 is an excellant little tractor. I used one alot plowing hillside vineyards. It pulled 4-14 inch plows with ease. No swing frame making going over things rougher. Probally has dry cluches. I've talked to people that work the older JD 450's and they say the dry cluches work just fine. The oler JD's were easy to work on. The 1010 is heavier and more tractor than what it looks like. The only problem I had with the JD 1010 is that it's not a "CAT".
