Thanks so much for your help so far. This is what I've found out based on the various tests that you've had me run. This is a 60A-7963, 24V system with generator.The charged batteries are coming in at #1 12.36 and #2 12.94Vdc. The ammeter does not move positive, but it shows a draw under preheat. I found the regulator on the inside of compartment under the seat. The hydraulic filter is mounted to the outside of the wall, covered by a guard. This tractor has a hyster 35,000 winch on its rear end so the #2 battery box is located above the hydraulic filter, with a guard below it. I removed the guard below the fuel tank and found the regulator inside there, although very difficult access. I cannot read which terminals are which, however based on your picture I polarized between the rearmost and middle terminals and got an arc that made me jump. No change in the ammeter, nor when I probe the battery with the multimeter, just reads the same 12.36 or 12.94Vdc. The next step was to disconnect the field wire from the generator, and replace it with a wire from Field to a ground (grounded off to a bolt on the oil cooler). I disconnected the Arm wire and bolted my multimeter + probe to the Arm stud; and the negative probe I grounded against the body. At low RPM I got 4-6.5Vdc, and when I ran the throttle up full I got 15.5 to 16 Vdc or so. So with a 24V generator (verified by nameplate) I'm thinking I should see well over 24Vdc on full throttle, so I think the generator is not producing enough voltage. I took it off and will hopefully take it in to get it bench tested and reworked. But it was producing some power, up to 16Vdc. Why are the batteries showing no voltage increase at all? How can the regulator be tested? Could it be stopping the charge from going to the batteries? When I reinstall the generator do I have to repolarize it again? How can you tell, on a very difficult to access regulator which terminal is which (arm/bat/field)? Once again, thank you for all your most generous help
