Hi, In BC. This behaviour is perfectly normal. When stationary and vibrating on hard ground, they will dance all over the place. Doing the same thing on softer ground will likely result in having to pull the roller out of a substantial hole which it will dig itself into quite quickly. That is why they had the over-centre remote clutch or remote throttle control, so that you could get moving before you turned the vibartor on or stop the vibrator before you stopped the tractor. Most of them drove the vibrator through a centrifugal clutch that engaged automatically when you revved the engine up and the remote control actually operated the throttle for this reason. The company that I currently work for has 3 of them, used for compacting house pads. The beauty of these rollers for this sort of work, assuming that your tow tractor is big enough, is that you can hang them right over the side of a fill to compact the batters as you build up each layer. Try doing THAT with a self-propelled vibrating roller. If you are planning on buying this roller, check the mounting rubbers that hold the roller to the frame, check the scraper bars that keep the drum clean or, if a sheepsfoot type, the bars between the rows of sheepsfeet that remove buildup of dirt from the drum. From your post, it apparently does vibrate but check the bearings, both for normal tightness and for end float. End float may allow the drum to hit the insides of the main frame. On a sheepsfoot version, it will also allow the sheepsfeet to hit the cleaners bars too. In fact, checking the sides of the cleaner bars on a sheepsfoot roller is one way of checking for end float in the bearings. Most of these rollers had at least two grease points on each end of the drum, one each end for the main bearings and one each end for the vibrator shaft. They should be greased at least every two hours of operation with a grease specifically designed for this purpose. The only such grease that I know of is Shell Alvania grease. Don't be sparing with it. This is largely the life of the roller. The hitch needs to be kept in good condition on these rollers, especially if you are going to hang them over batters, because the vibrators do give them a bit of a workout, as does being towed behind a crawler tractor. It pays to throttle down before changing direction. Safety chains are a good idea too, again especially of you are hanging them over batters. None of the ones that I have operated had any oil in the drum so there was nothing to leak out. Hope this helps. You have a wonderful day. Best wishes. Deas Plant.
