550 ford swing chain tension
larry in ky
08-08-2007 19:18:51
anybody else having this problem?..
it keeps blowing the hose which connects the two cylinders..... ..... ..
it's a 76 mod.near's i can tell
ttman4
08-12-2007 20:30:50
 Re: 550 ford swing chain tension in reply to larry in ky, 08-08-2007 19:18:51
Larry, I currently have an old 4500 that the swing cyl have been repacked several times. I used to have that equalizing hose between both cyl, but my swing cyl have gotten so bad that they leak internally so bad it blows hose off quick. I had to "bleed" off frequently to keep slack out of swing chains.
I still got the equalizing hose, but I plumbed a "T" in, ran a hose up to a low press. return spot & now the internal leakage just returns to reservoir without waste. I"ve done this same trick on a 550 & 555 I used to have.
larry in ky
09-10-2007 19:45:42
 Re: 550 ford swing chain tension in reply to ttman4, 08-12-2007 20:30:50
thanks very much for your reply n advice!
i don't know the history of this rig but i'll certainly keep your idea in mind.
if i can figger how to get th cylinders off, i'll try packing them 1st i think .....can you tell me exactly how you plumbed yours??
thanks again bud:+)
larry
ps
sorry to be so long getting bhack to you but i'm not real litterate with this thing :+)
Roy Suomi
08-11-2007 09:24:21
The "chain swing thing" is 2 halves of chain connected to the ends of the swing cylinder chrome ends and connected to the swing post by means of a pin..Oil pressure is routed to the rod end of the swing cylinders to swing the backhoe from left to right..Leakage in cylinder packings will result in filling the Barrel ends of the cylinders with oil and transferring oil from one cylinder barrel to the other..Eventually , there will be too much oil in there to transfer from one to another..The "jumper hose" is a clamped on type that will either blow apart or push the hose off the hose barbs...Oh , those swing chains are real expensive..$ 600.00 a half , last time I bought them...
Case450
08-11-2007 18:33:01
There's one of these machines for sale in the equipment trader around these parts for five grand. Apparently everything works except this chain swing thing. What exactly is that?
Roy Suomi
08-09-2007 13:39:12
You need to repack a swing cylinder or two..
larry in ky
08-09-2007 18:48:47
 Re: 550 ford swing chain tension in reply to Roy Suomi, 08-09-2007 13:39:12
thanks for your reply roy..
i disconnected the rt.cyl.hose n run the boom thru several cycles(similar to bleeding brakes into a jug).the tension is back for now...i've used it 2/3 hrs. now .so far so good...??
reckon i can be so lucky??"+)
JF in CT
08-09-2007 10:30:18
Sounds like one of the cylinders is "bypassing". In that case the fluid would have no where else to go.
Jim
larry in ky
08-09-2007 18:52:04
 Re: 550 ford swing chain tension in reply to JF in CT, 08-09-2007 10:30:18
thanks for your reply jim..
i wonder if there's a proceedure for bleeding after a hose bursts maybe..?
