955 traxcavator torque converter seal
daveg
08-19-2007 07:14:54
i have a 955 traxcavator with a leaking front torque converter seal.is it possible to replace inside the machine without pulling the motor or trans and if so ,how much trouble is it?the machine still works but i have to add oil regularly.any help would be greatly appreciated.
Bob/Ont
08-19-2007 18:49:44
 Re: 955 traxcavator torque converter seal in reply to daveg, 08-19-2007 07:14:54
Dave what 955 do you have, K or L? I get the feeling it's one with a flexable drive coupling. Yes you can take the coupling out and change the seal but check the input shaft bearings for movement. If the drive biscuits have tears in the rubber you should do an engine alignment and replace them. Email me if you need to do that and I will help you.
Later Bob
hectorgemme
08-19-2007 08:32:50
I think the best way is to remove the motor with the torque for changing seal and maybe the bearing.
