crawler chains
andrew 135
08-21-2007 05:06:49
does anyone know the procedure for rebushing track chains on a 420c john deere??
CHinNY
08-22-2007 03:36:53
 Re: crawler chains in reply to andrew 135, 08-21-2007 05:06:49
Drop your tracks off here and write me a check:) Labor is $175. per side.
joed
09-06-2007 17:47:11
 Re: crawler chains in reply to CHinNY, 08-22-2007 03:36:53
CHinNY said: (quoted from post at 03:36:53 08/22/07) Drop your tracks off here and write me a check:) Labor is $175. per side.
Where do I drop them off??? And who's name goes on the check?
putz54143
08-21-2007 14:34:14
would this 420 be 4 sale hwy 28 in the up?
Mike M
08-21-2007 05:21:21
While were on the subject. What way for direction of rotation is the track pads and chain to go on ? or doesn't it matter ? I have a real small Kubota track hoe with steel tracks and wonder if they are on the right way ?
bob plumadore
08-21-2007 16:40:45
 Re: crawler chains in reply to Mike M, 08-21-2007 05:21:21
place a bloce under the grouser bar on the pad with the bushing
this is going to end up uder the Idler/ backe the tractor all the way to the other end, run a long bar thru the open links only go thru the inside link about 1/2 inch
have soe one slowly move the machine fordward so that the bar hangs in the sprocket, let the sprocket pick up the track. Once you have it on top you can either carry the track across the top rollers as the machine moves fwd or hok a chain t it and to the bucked and by keeping tension on the chain assist the track over the I dler
according t the type master link, eith drive a pin thru or bolt the link togeather. EMil me and I can probably scan this t you directly from a service manual
720 in pa
08-21-2007 12:27:02
bushing in each link should be towards rear of machine,wide part of link towards front.
Mike M
08-21-2007 19:18:47
 Re: crawler chains in reply to 720 in pa, 08-21-2007 12:27:02
Is that on the top or bottom ?
720 in pa
08-22-2007 03:28:35
 Re: crawler chains in reply to Mike M, 08-21-2007 19:18:47
that is on top.sorry i didnt include that right away.
Bob plumadore
08-21-2007 05:10:06
If you have to ask you can't. it takes specalized tools, a track press. either take your tractor to an undercarrage shop or remove the chains and take them.
andrew 135
08-21-2007 16:27:31
 Re: crawler chains in reply to Bob plumadore, 08-21-2007 05:10:06
I have the ability to construct a press, I just need to know the measurements and tolerances for the bushings
