jd 450e oil pump removal
dickpoinsett
08-22-2007 13:23:01
Anybody out there had problems removing the engine oil pump from a JD 450 engine. I removed the gear nut and two pump cap screws per the shop manual. Pump body came out OK, but the input shaft will not separate from the drive gear...Any ideas would be greatly appreciated.
JCSinGA
08-22-2007 19:35:49
 Re: jd 450e oil pump removal in reply to dickpoinsett, 08-22-2007 13:23:01
The "input shaft" is tapered and they do get tight sometimes, I've got a puller that I use if the engine is out, if not, a thick body chisel between the gear and front plate driven up snug then install the nut back on flush with the end of the shaft and rap it with a hammer.
