Penn
08-23-2007 04:43:05
Re: case 1150B sprocket / Track Removal in reply to uncle, 08-22-2007 19:52:31
You could try as there is nothing to lose and a lot to gain,remove the gease drain valve from the adjuster,put a block of hardwood in the sprocket and slowly reverse back,this will pull back the idler and you would be letting the adjustment off anyhow if you were splitting the track,you would need the slack to rejoin it,when you have the idler back fully and got the block of wood out get all the slack of the track to behind the sprocket,block up the track in front and behind the top roller,jack up the machine just enough to clear the sprocket at the bottom,lift the track off the teeth at the top and secure the track firmly,keeping your hands away from between the track and sprocket undo the bolts and remove the sprocket,that is of course you have enough slack,I think you will,if not you will have to find the master pin,I think its highly unlikely that anyone would put in anything else but the master pin as they come with new chains,you will have to clean the end of every pin to find it,it will either have a dimple or a raised centre depending on the make but it will differ from all the rest,it will save a lot of labour if you can get it on without splitting and its worth a good try. P
