D 8 add on hydrolic steer cluch valve how does it work
rancherruss1916
08-24-2007 12:04:03
the two spool vlve on my d8 cat is giving me fits.this is an add on that replaces the two sticks thea open the steering cluches. so i changed it with another one i had not noing that a regular valve like a loader valve will not work. both valves are gresen valves and look identickle but are set up different inside. can anybody explain how these systems were set up. almost like it is in a float position all of the time. thanks for any help
jerry 27
08-28-2007 12:31:14
 Re: D 8 add on hydrolic steer cluch valve how does it work in reply to rancherruss1916, 08-24-2007 12:04:03
We did a lot of those conversions late 50s alon about i956 or so.. When the thing was too jerky
there was a small fitting we put in the line at the valve with an orfice that cut the flow down and made it work mor like the operators wanted them to feel.
rancherruss1916
08-25-2007 03:41:28
thanks guys for the help, all i had to do was read open and closed hyd system and i t finally clicked, lol ever have a blonde moment. the valve that is on the cat works but is really touchy about how you pull the levers, and i thought id chnge it with one i had off of a loader i scrapped, guess not lol, thanks again
AJK
08-24-2007 15:48:32
 Re: D8 Hyd Steer in reply to rancherruss1916, 08-24-2007 12:04:03
You sure the pump is working?,as I remember you had a small pump,reservoir, control valve,cylinder,oil under pressure entered the control valve,you pull the lever oil is forced to the respective clutch cylinder,the cylinder rod pushes the the clutch throw out and the clutch is disengaged,let the lever go and the oil is allowed to escape back,so the control valve is single acting,it has no hold position like a loader valve would have,the circuit did have a pressure relief valve,there were at least two types that I have come across,one type is at the link below its about the patent,there are two parts to it so click on next,you will need to download them and enlarge them.
AJ
rancherruss1916
08-25-2007 08:17:19
 Re: D8 Hyd Steer in reply to AJK, 08-24-2007 15:48:32
thanks again, after looking at the pics you gave me , i noticed my cat has three hoses that go into the top of the tranny.and your pic only has two going to the cylider. have to kep in mind that this was an add on setup to my cat had manual sticks at one time. shes an oldy lol. 2u model. thanks again
John Tilson
08-24-2007 15:23:42
Im sorry that I can't be much help, but have you done a "search" here in the little box above?
Try "Closed Hydraulic valve" and Open Hydraulic valve system and you will see a few posts from previous questions like your own.
Also try "adding on a backhoe". I found some this way who are asking your same question. Otherwise I am no help at all.!!!
