JD 450c rear crossbar
Ross Berck
08-29-2007 21:04:22
third party image
Im new to crawlers and this is my first machine. I am replacing the trackrail,bottom rollers and sprockets and need some advice regarding the rear cross bar. There is slop around the bar where it goes thru the track frame. How critical is this and how do I fix it. Thanks, Ross
John-Paul
08-31-2007 13:00:53
 Re: JD 450c rear crossbar in reply to Ross Berck, 08-29-2007 21:04:22
bushings made at machine shop is your best bet. Tell them its gonna be under serious abuse and get the toughest metal (or steel alloy) they have. You dodnt want brittle though, it should have some spring to it. Kinda like titanium. Titanium is bouncy (IN THIN SHEET). Titanium alloy isnt too bad price wise, pure titanium would be far too expensive and I dont think as good for this as alloy. Im thinking of getting some for our bushings we will have to replace eventually.
Make sure your machine shop is willing to work with it first. If not steel with high carbon maybe your next best bet.
Link
"Titanium and titanium alloys are non-ferrous metals with excellent corrosion resistance, fatigue properties, and high strength-to-weight ratios. Products differ in terms of composition, grade, shape, dimensions, and features. Commercially pure, unalloyed or very low alloy titanium does not contain or contains only very small amounts of alloying elements. By contrast, titanium alloys contain significant amounts of added elements or constituents. Clad or bimetal titanium alloys consist of two different alloys that are bonded integrally together. Metal matrix composites have a composite or reinforced metal or alloy matrix filled with a second component, which may be in particulate, chopped fiber, continuous filament, or fabric form. Other unlisted, specialty or proprietary titanium and titanium alloys are also available. These materials are often based on a unique alloy system, use a novel processing technology, or have properties tailored for specific applications."
Titanium Alloy Types and applications
http://www.allvac.com/pages/Titanium/Default.htm
Roy Suomi
08-30-2007 21:35:54
If it bothers you profoundly , you can take the track frame off and weld up the holes...Early C's had loose fit bushings on the front crossbar, This allowed the track frame to float some..Later units had a rigid mount on the front crossbar..On these later units , some tightening should probably be done..I personally wouldn't worry about it too much..It won't hurt a darned thing..You still can align the track frame to sprocket with shims and new or welded up lock plates.
Roy Suomi
08-30-2007 13:56:20
Don"t worry about it..That"s normal wear for a C model..
Ross Berck
08-29-2007 21:05:13
third party image
more pics
