missing 80 cent bolt + $1.00 washer causes $500+ damage!
John-Paul
08-31-2007 22:49:30
Wow, the guy that owned this skidsteer before us wasnt too bright I guess. He installed the drive sheeve which HE modified, without a bolt and washer to hold it to crank. Bolt was 80 cents and washer was $1 from bobcat dealer. Damage, one shot drive sheeve ($350), one worn belt ($90) one bad bearing in variable drive speed ($70 at napa for heaver bearing it apears). Total cost to repair $542. Now I just hope the taper on crank isnt messed up or Ill need to replace that too.
Anyone know where to get aftermaket parts little cheaper then bobcat dealer? If crank is messed up on sheeve end Ill need, all required gaskets to get in bottom end (front and rear seal crank aswell?) Taper bearing in front of engine. Crank itself, crank bearings and new rod bearings. If you know of a good source please let me know.
John-Paul
08-31-2007 23:31:47
 Re: missing 80 cent bolt + $1.00 washer causes $500+ damage! in reply to John-Paul, 08-31-2007 22:49:30
forgot to add its a bobcat m600 with vf4 (4 cylinder gas) engine.
