Cat D4E
DLJ
09-01-2007 22:12:52
I have a Cat D4E SA Serial 29X711 Can any one tell Me if I can put a Pto Drive on this tractor.
Old Magnet
09-02-2007 08:07:24
 Re: Cat D4E in reply to DLJ, 09-01-2007 22:12:52
Yes, it can accommodate a pto. It has the splined output shaft (behind cover plate) to accept a coupling. The output shaft does have a gear reduction of 1.73 (22 tooth in/38 tooth out).
Not quite sure which Cat pto attachment would fit the mounting bolt pattern but suspect something from the 40A & D4D up would work. A pto is kinda rare on that late a model.
DLJ
09-08-2007 10:30:28
 Re: Cat D4E in reply to Old Magnet, 09-02-2007 08:07:24
Thank You For Information, Do you Know where One Of The Unit Might Be Found?
Bob/Ont
09-02-2007 07:34:02
The PTO it has is to drive a winch or cable control. Comes through the top shaft of the trans and runs at engine speed.
Later Bob
DLJ
09-08-2007 10:33:41
 Re: Cat D4E in reply to Bob/Ont, 09-02-2007 07:34:02
Thank You Bob For The Information, Do You Have Any Idea Where One Can Be Had From?
Thank You.
