Backhoe advice
Knucklebuster
09-03-2007 19:52:00
I have a farm in the NC mountains. I have a Ford 550 backhoe that just seems a little too unstable on the hills and inclines I need to work on. Are my concerns valid? What kind of slopes are too dangerous? What other machines might be more suitable? Wish I had an attachment for my Caterpillar D47U..... ..... Thanks
David
john_bud
09-04-2007 20:29:44
 Re: Backhoe advice in reply to Knucklebuster, 09-03-2007 19:52:00
Are the tires filled and are you using wheel weights? That tall boom makes the machine very tippy and extra down low weight helps keep it planted.
jb
Case450
09-04-2007 13:47:29
I don't think there is a backhoe made that is really stable...like the other guys said, keep your bucket low, get the downhill stabilizer out and as close to the ground as possible without hitting, swing that boom to the uphill side and go easy.
If it feels like your gonna lose it back off. If it's bad enough I back into my grade with the hoe uphill then get settled in, dig a trench for the uphill side tires to ride in and back in to the end of the trench, set up and dig another trench until i get where i need to be. A lot of digging but i'd rather spend an extra hour digging my way to the site then crushed under my machine! I find crawlers with backhoe's tend to slide sideways as well on account of the tracks. There not too much better either. If you do a LOT of digging, maybe an excavator is more up your alley.
Mike M
09-04-2007 11:28:31
Any backhoe I have ran ( about 5 different ones )
have not been real balanced or stable. Always too light on the front and top heavy. If you have to go across a hill swinging your boom to the uphill side will help.
VaTom
09-04-2007 04:47:25
I live on a Va mountain and have slopes far too steep for even a crawler. Transversing, I'm comfortable with rubber tire on 20%, slowly. Up/down considerably more. Use those stabilizers and hoe to keep me shiny side up.
Kyhayman's correct. If it doesn't feel good, back away. I know of a Case hoe available here if you're interested in adapting. Came off a 580CK. Needs a line brazed, otherwise works well.
kyhayman
09-03-2007 20:47:36
My advice is 1. if it feels ok and ppl that know say its too steep, stay off of it. 2. if it doesnt feel ok and other ppl that know say it is, trust your gut anyway.
If something goes wrong, its still your life and dont take chances with it. Personally, I dont like anything more than 10% with a backhoe.
