ford tractor 7600 key wiring
U9 U9 CAT
09-04-2007 08:14:43
I need to figure out wiring for the igniton switch, It's only 5 wires, I got hot coming from the starter to the key. Got the big problems fixed with this old girl now just got to get her to crank Need help getting started any advise Thanks Mike
AJK
09-06-2007 16:27:37
 Re: ford tractor 7600 key wiring in reply to U9 U9 CAT, 09-04-2007 08:14:43
The hot wire should go to #1 terminal,switch on to the first position,find the hot terminal,connect the wire thar puts on the dash lights and connect it to that,hold the switch in the start position,find the terminal and connect the wire for the starter,if you have a heat position find which terminal is hot when the switch is in heat position and put the heat wire there,the last maybe for the lights or.its trail and error.
AJ
