Cat 977 quit moving
jamesh
09-05-2007 17:34:18
Just recently purchased a Cat 977 track loader that I use for logging.The other day I was coming into the landing with a load of logs when it came out of gear(powershift)When I put it back in gear it wouldn't move either fwd or rev.After topping off trans oil and replacing filter it finally moved a little but only at full throttle.Any input would be appreciated before I start tearing things apart without really knowing where to start.Thanks Jim
Bob/Ont
09-05-2007 18:00:32
 Re: Cat 977 quit moving in reply to jamesh, 09-05-2007 17:34:18
What serial# approximatly?
Later Bob
jamesh
09-05-2007 18:04:25
 Re: Cat 977 quit moving in reply to Bob/Ont, 09-05-2007 18:00:32
53A4986
Bob/Ont
09-06-2007 05:48:04
 Re: Cat 977 quit moving in reply to jamesh, 09-05-2007 18:04:25
Jim,I take it what you mean by coming out of gear was the shift lever went into neutral by it's self. There is a spring to force it out of gear when you shut down and the trans pressure drops so you don't restart in gear and it start moving. Sounds like you have low trans pressure. Has the trans been over heating lately?
Later Bob
jamesh
09-06-2007 15:56:07
 Re: Cat 977 quit moving in reply to Bob/Ont, 09-06-2007 05:48:04
Bob,Iwent up today and started the loader. It moved first thing for about 5 minutes but only at full throttle.I'm going back this weekend to check pressure at transmission hydraulic control as per manual Is there anything else I should be looking at?Thanks Jim
Bob/Ont
09-06-2007 18:23:56
 Re: Cat 977 quit moving in reply to jamesh, 09-06-2007 15:56:07
I think pressures are going to tell you a lot Jim.
Glad you have a manual, read up on how the valve controls the pressure. If it happened all of a sudden it may have a broken spring or stuck spool. Pressure drop from high to low idle should only be 10%. Try at low idle in all gears(F R 1 2 ). Come on back when you find out.
Later Bob
Bob/Ont
09-06-2007 18:26:44
 Re: Cat 977 quit moving in reply to Bob/Ont, 09-06-2007 18:23:56
Also make sure your linkage is letting you get fully into all gears too.
Later Bob
