Cat D7 ( Broke)
Doddsracing
09-06-2007 20:04:47
I have a D7 3T with a cable blade.I broke the pin that the blade swivels on,this an angle type blade,it broke right between the blade and the push bar. Does anyone have this pin? It is about 20" long and has a 4.5" x4.5" square head one one end. Any help would greatly apprecated
GeneMO
09-29-2007 00:24:27
 Re: Cat D7 ( Broke) in reply to Doddsracing, 09-06-2007 20:04:47
Do you have a CAT dealer nearby?
Gene
bob plumadore
09-07-2007 07:32:03
A good welder can put hte pin back togeather and it will be as stong as ever.
135 Fan
09-06-2007 20:34:19
I've seen the swivel pins for sale at a local heavy equipment repair and parts shop. If you can't get the exact pin, you might be able to match the diameter or change to a newer pin style. Dave
Billy NY
09-06-2007 20:25:53
The parts book I have for a 7A blade, Serial Numbers 17C5001 to 17C19642 shows part #3F6149 for the pin you describe, not sure of the availability of a part like this, worst case you have a local machine shop turn one made of the appropriate grade steel.
