HD5 - HD6
P BLAKEMORE
09-07-2007 08:51:41
DOES ANYONE KNOW IF THE OLDER HD5 AND HD6 USE THE SAME REAR ENDS. ALSO I HAVE HEARD THE HD5 IS CONSIDERED WEAK IN THIS AREA. ANY FEEDBACK WOULD BE APPRECIATED. THANKS PAUL
Joe McCann
10-26-2007 09:57:31
 Re: HD5 - HD6 in reply to P BLAKEMORE, 09-07-2007 08:51:41
I am looking for 2 or 3 bottom rollers for a HD5.
Does anyone know where I can find some?
Thanks in advance for you help.
Joe
WayneB
11-19-2007 12:30:03
 Re: HD5 - HD6 in reply to Joe McCann, 10-26-2007 09:57:31
a fellow on ebay has a set: vender name
andysengnprts
P BLAKEMORE
09-09-2007 17:29:10
THANKS TO ALL FOR THE INFO ON THE HD5 AND HD6. THIS INFO WAS VERY HELPFUL. PAUL
Bob Blue
09-07-2007 18:24:06
The only weak link in the 5 and 6 rear end is the lack of adding oil to the full levels and not getting enough oil to the intermediate gear. They will go first and its uaually because of a leaking sprocket to cage bearing seal and the operator runs it low on oil over time.
hectorgemme
09-07-2007 17:13:55
The hd5 and hd6 use the same final drive,stering cluch,transmission and master cluch must hd6 use 1 more roller and the hd5 use a DETROIT 271 motor and the hd6 use A BUDA ALLIS 344 and these machine are very good if you have a good attention.
dej(jed)
09-07-2007 11:37:59
The HD6 supposedly uses the HD5 rear end and is over powered. I have had a couple of HD 5's and they have been great machines. They are also easy to work on compared to the old CATS.
jdemaris
09-07-2007 14:06:08
 Re: HD5 - HD6 in reply to dej(jed), 09-07-2007 11:37:59
I've got both, and there's not much difference in pushing power. The HD6 though, with the Buda 344, is quietier - and certainly not overpowered since it's geared so high. I wish it had a lower first gear. HD6 was tested with a maxium pull of 12,000 lbs and rated at 40 horse drawbar and 60 horse PTO. HD5 with the Detroit Diesel was rated almost the same at 38 horsepower at the drawbar and 58 horse at the PTO with a maximum pull of 10,000 lbs.
I love the Buda 344 engine as far as how it starts, runs, and sounds. But, engine parts are very expensive since the 344 is kind of a rarity. For that reason alone, I like the Detroit better.
jdemaris
09-07-2007 10:52:26
Somebody like Hector Gemme probably knows a bit more than I do. But . . . from anything I've read or seen, the HD6 IS a HD5 - but repowered with a Buda four-stroke-cycle engine due to a legal disgreement and fight between Allis Chalmers and Detroit Diesel. I've swapped many parts between the two - but cannot tell your for sure what is, and what is not - interchangible. And of course, HD6s differ as they get newer.
In regard to finals being weak? I worked as a Case, AC, and a Deere mechanic - and I've heard that same story with all of them. I think they hold up fine when used and maintained properly.
