Ford 555 with 201 injection pump problems
AmeriKen
09-07-2007 11:00:11
My Ford with a 201, 3 cylinder diesel has been getting more difficult to start until I couldn"t get it to start at all. I took the injection pump to the shop, and they told me that it needs a complete build (head and rotor worn out), but it's more expensive than I"m willing to pay on this money-pit tractor.
Does anyone know where I can get a good used injection pump or a rebuilt one?
AJK
09-07-2007 14:34:50
 Re: Ford 555 with 201 injection pump problems in reply to AmeriKen, 09-07-2007 11:00:11
Is your engine a Perkins badged Ford with a CAV rotary pump.
AJ
jdemaris
09-07-2007 13:49:50
Most shops work on an exhange basis, and the exchange is based on the head & rotor being good in your old pump. If they know your's is bad, the price goes way up. What price were you given, and are your sure the head & rotor assembly is bad? When worn, the first symptom is usually bad starting when hot, but better starting when cold. I've seen many a tractor with a worn head & rotor, that the owner had to pour cold water on the pump to get it started when hot. What are your symptoms?
AmeriKen
09-07-2007 15:40:40
 Re: Ford 555 with 201 injection pump problems in reply to jdemaris, 09-07-2007 13:49:50
The diesel rebuild shop took it apart and inspected it. The rotor and head were worn and scored. The total if rebuilt is $1150 for sure and maybe upwards of $1300.
There's no way! I'll part the tractor out before I pay that much.
jdemaris
09-08-2007 05:53:22
 Re: Ford 555 with 201 injection pump problems in reply to AmeriKen, 09-07-2007 15:40:40
You still didn't specify what the symptoms were. Cold starting or hot starting problem? In regard to pump prices - if it's a CAV, usual price is around $550 for an exhange pump or $650 outright. If it's a Stanadyne, around $400 for exhange and $500 outright. The head & rotor alone can cost $175 to $300 depending on pump model and parts source.
JML755
09-07-2007 12:44:05
There was a place online, I recall, that sold them. Don't have the link, but a google search should turn something up. However, when I researched it several years ago, the local rebuild shop was within $75 on the basic rebuild from the online site, so I went with the local guys. Ended up adding several hundred for a bent shaft they found after getting into it. Seems to me the basic rebuild was around $400 or $500.
