977 Cat No trans pressure
jamesh
09-10-2007 18:01:04
Took a guage up to check pressure at transmission control as per manual.No pressure at all on guage.Took valve body apart and found everything ok.Cleaned it up put it back together still no pressure.Is pump bad even though it's pushing oil through filter?It's a long ways back up the hill to run more tests so any input is greatly appreciated. Thanks Jim
Bob/Ont
09-10-2007 20:09:06
 Re: 977 Cat No trans pressure in reply to jamesh, 09-10-2007 18:01:04
Jim,the pressure control may not be getting above initial setting. Did you see any pressure at all on the gauge, like maybe 50 to 70 PSI?
Did you ever get my email? Try me at 104060.414@cs.com
Later Bob
jamesh
09-11-2007 06:25:51
 Re: 977 Cat No trans pressure in reply to Bob/Ont, 09-10-2007 20:09:06
Bob,Only slight pressure on guage at full throttle.Tractor will move at half throttle when first started but after it warms up it slowly gets worse until it won't move at all even at full throttle.Thanks or all your help.Jim
Bob/Ont
09-11-2007 07:05:04
 Re: 977 Cat No trans pressure in reply to jamesh, 09-11-2007 06:25:51
Jim send email and we can discuss what you read in manual. System operation has important info to help you.
Later Bob
jamesh
09-11-2007 13:01:05
 Re: 977 Cat No trans pressure in reply to Bob/Ont, 09-11-2007 07:05:04
Bob For some reason email won't go through. Jim
Bob/Ont
09-11-2007 14:53:55
 Re: 977 Cat No trans pressure in reply to jamesh, 09-11-2007 13:01:05
Jim, try it through this post then.
Conversation could get a bit long for on here.
Later Bob
