Monarch 10 ton crawler
Raymond H. Schm
09-11-2007 08:52:44
I own a Monarch 10 ton crawler.It was mfg'd in about 1917.I would like to do a complete restoration.Does anyone know of any manuals,parts lists or diagrams,available parts or any other units in existance.I would appreciate any help or information.Thanks Much Ray
135 Fan
09-12-2007 21:16:11
 Re: Monarch 10 ton crawler in reply to Raymond H. Schmidt, 09-11-2007 08:52:44
According to my info the 10 ton is a model F and was renumbered the 75 when AC purchased Monarch in 1928. The model F is 60 HP. Monarch Tractor Company was founded in 1913. There is a picture of a restored 75 in the Giant Earthmovers an illustrated history. Strangely enough the owner of it is not too far away from me but I don't know him and the book was published in 1998. His name is Bill Senior of Ardrossan, Alberta Canada. Sorry don't have a number. I'm sure a good library or book store would have more pictures and info to help you. Dave
Raymond H. Schmidt
09-13-2007 04:46:27
 Re: Monarch 10 ton crawler in reply to 135 Fan, 09-12-2007 21:16:11
Dave,Thanks for the info.I will follow up on these.Thanks very much Ray
noncompos
09-11-2007 21:31:36
Didn't remember Monarch is listed in a 1930 McCord gasket catalog, but listings don't go by ton ratings; here they are if they're any help:
"C-20/30, E-25/40, D-35/60...Beaver JB";
"C-E-D-G. Rating 20/32-25/40-35/60..Beaver JC-JD";
"F. Rating 50.....Beaver RX-RY"
"H-50 Rating 40....Stearns DU". (I don't understand the C-E-D-G ratings; maybe one of the ratings applies to two models).
I started to send the various b/s's out of the same catalog, but it's confused, too: one line shows "Beaver Motor 4cyl Models JA and JB , 41/2x6, (one cyl head);
but the next line is "Beaver Motor 4-6 (cyl) Models JA-JB-JC-JD 41/2x6 and 43/4x6" with cyls cast in pairs (two or three heads, respectively);
the RX-RY line reads "Beaver Motor 4 and 6 (cyl) Models RX and RY 61/2x7", with cyls cast in pairs (2 or three heads). One could guess the RX is the 4 and the RY is the 6, but even if true, still leaves the JB confused.
The Stearns motor is no trouble: it isn't listed, which I would guess meant such low prod that McCord didn't carry the gaskets, but the Monarch section shows only need one head gasket, whatever it is. I'll check the motor lists in some other old catalogs to see if I can clarify any of the above. With sympathy, Bud
Raymond H. Schmidt
09-12-2007 04:56:23
 Re: Monarch 10 ton crawler in reply to noncompos, 09-11-2007 21:31:36
Dear Bud,Thanks for the info,I will follow up.Ray
noncompos
09-11-2007 10:02:04
You may already have tried these:
A: Monarch was acquired by Allis-C, apparently in 1928, altho my notes show Monarch prod 'till 31 or so; have you tried contacting Allis for any historical tech info?
B: Don't over look the possibility, as in UStrac below, that company papers, including tech info or manuals, may've come into the collections of the local (Watertown, Wisc) public library or museums, especially technical or business-oriented museums. Good luck.
Raymond H. Schmidt
09-11-2007 10:38:40
 Re: Monarch 10 ton crawler in reply to noncompos, 09-11-2007 10:02:04
Thanks for your help,I will check those sources,Thanks Ray
