Fiat Allis 11B noise when turning
jkloepping
09-13-2007 23:33:12
I bought a early 70s Fiat Allis 11b, s/n 25L17799 and I notice something now that I didn"t when I first checked it out. (darn!). When I turn, unless I stomp on the brake hard, I get a loud "chattering" sort of sound from the side that I am applying the brakes to. Is this normal, or does someone recognize this problem?
Also, I have a four way hydraulic blade that can be manually angled to either side by moving the blade mounting pins between three holes. The pins where the blade attaches to the frame are really loose. It"s a sort of ball and socket arrangement, but the ball is quite loose. Is there some wear piece that is missing, or has it really worn out? The dozer is otherwise super clean.
