Bobcat X220 Excavator Parts Source Needed
uncle
09-15-2007 16:26:30
I just got this Bobcat and the cab did not swing.
I pulled the lines and it was getting hydraulic flow through the valve body so I pulled the motor.
I could turn the gear on the swing motor and it felt rough so I pulled it apart.
The internal splines on the output gear are gone.
I am looking for a swing motor or at least the output gear in the swing motor. I have the part number on the motor and on the gear if anyone knows a source.
Brian
JCSinGA
09-15-2007 19:17:55
 Re: Bobcat X220 Excavator Parts Source Needed in reply to uncle, 09-15-2007 16:26:30
I'm certain Bobcat Corp. did not make the actual swing motor but they are excellent at "locking up the parts" which means even if you found the supplier you likely could not buy the parts from them.
I dont know of any aftermarket Bobcat parts suppliers, but just for curiosity do a search for Flint Hydraulics to see if they can help at all with the motor parts.
