Roller specs. 44A D6B Old Magnet
U9 U9 CAT
09-16-2007 19:01:54
Ok, I got my bolt bars done. Measured my collection of rollers, I got some double flange ones at 8.00 O.D. that are welded up good, Then I got them wore down to 7.250. but I have about 20 rollers.. I was going to put the single flange, wide middle one, next to the sprocket and anoughter single flange in the front. How should I put the rollers according to diameter? Big one in the middle on each side closes to the sprocket? Thanks
Old Magnet
09-16-2007 19:48:45
 Re: Roller specs. 44A D6B Old Magnet in reply to U9 U9 CAT, 09-16-2007 19:01:54
Put the 7.25 in rollers in the scrap bin or weld them up. Minimum good reusable is 7.50 in. If you have to use worn out ones go with the pattern you describe.
U9 U9 CAT
09-16-2007 20:39:43
 Re: Roller specs. 44A D6B Old Magnet in reply to Old Magnet, 09-16-2007 19:48:45
Thanks, My hard bar has been cut, alot, they have built the inside of the roller frames to make up for the shortend bar, what will this hurt, and is 500 dollars for a used bar, good. Thanks again I 've got my work cut out for me now I 've got to go weld it up ..
Old Magnet
09-16-2007 22:09:21
 Re: Roller specs. 44A D6B Old Magnet in reply to U9 U9 CAT, 09-16-2007 20:39:43
Running a shortened hard bar and making up the difference at the track frames will put a torque on the frames that is transmitted to the dead axle. Not a good idea. Depends on how much leverage is involved. $500 for a used hard bar seems high to me but they aren't all that common. Most have a spring. Does the hard bar have a Cat part number?
U9 U9 CAT
09-17-2007 05:02:53
 Re: Roller specs. 44A D6B Old Magnet in reply to Old Magnet, 09-16-2007 22:09:21
I don't know the part number but its on a old salvage tractor that has been donating its parts to me
