FiatAllis 11B Idler Roller Needed
H2
09-22-2007 05:24:04
I'm looking for a good used idler roller for my fiatallis 11b. Mine is worn on the left side of the rib and the bearings are worn.
Any suggestions?
Rays
09-22-2007 12:37:17
 Re: FiatAllis 11B Idler Roller Needed in reply to H2, 09-22-2007 05:24:04
Hi, If you are looking for the top roller in the center of the track frame? I should have a good used one. email or call1-330-223-1913
bob plumadore
09-22-2007 06:50:31
Are we talking about the Idler, the Big Wheel at the very front? If so I would weld up the hull, and replace the bearings and O rings on the seals.
You can build it up on a rainy day. a suggestion, blow a hole in the side of the Idler to relieve pressure from internal heat build up. Be sure to weld it shut when you are finished
H2
09-24-2007 10:46:41
 Re: FiatAllis 11B Idler Roller Needed in reply to bob plumadore, 09-22-2007 06:50:31
Any more suggestions on how to weld it up? Looks to be only the right side of the rib worn due to previous owner's misalignment. Can it be welded on the machine? Also, how worn is too worn to run?
bob plumadore
09-24-2007 11:08:23
 Re: FiatAllis 11B Idler Roller Needed in reply to H2, 09-24-2007 10:46:41
Yes you can do it on the tractor. I get the track out of the way, either jack up the front or run it out past the end of the track weld a lug on the the idler, get a comfortable seat, and a tube of 7018 rods, blow a hole in the side of the idler, everyone has their own technique. I I hold the rod in the center of the idler and turn it with my other hand,when it reach bottom roll it back make as many passes wide as the Center is worn off
continue thsi until you get that half of the idler built up, then knowck the lug off and move it 180° do the other half,then weld up the blow hole, it will smoth its self, there is no need to grind.
H2
09-25-2007 04:53:37
 Re: FiatAllis 11B Idler Roller Needed in reply to bob plumadore, 09-24-2007 11:08:23
Thanks for the help Bob. I appreciate it.
I've never drove out a track pin before. Is there any certain place it needs to be to make driving it out easier? I've already got the track loose.
