580g trans fluid plug
howard ewing
09-25-2007 02:29:13
where is the drain for the trans? Could it be the drain on the bottom of the 4wg gearbox? What fluid is best for re-fill? thanks, Howard.
AJK
09-26-2007 00:45:46
 Re: 580g trans fluid plug in reply to howard ewing, 09-25-2007 02:29:13
The 580G power shuttle is seperate from the transaxle oil,the axle oil and finals drives is drained from the lowest point,there are two drains for the shuttle and torque,there is a plug on the shuttle sump pan,the torque is drained by removing the plug in the bottom of the bellhousing and turning the engine by hand till the TC drain plug lines with the plug hole use a socket then to undo the plug,go to the link below for some pages from the hand book with how to and oil/fluid to use.
AJ
