Allis Chalmers HD-4 Steering Problem
rudy2
09-25-2007 11:01:55
I finally am getting around to the steering on my HD-4 crawler after spending all summer restoring everything else.
The tractor will turn one direction but not the other. So in order to steer it I have to travel back and forth until I get it jockeyed around. If a steering clutch were slipping I would expect the tractor to turn when trying to go straight, but it travels straight just fine. So I am thinking one of the clutches is not disengaging instead. Does this sound right? If so, is there any way to free up the clutch without disassembling it? Thanks.
Randy
Rudy2
09-25-2007 21:34:23
 Re: Allis Chalmers HD-4 Steering Problem in reply to rudy2, 09-25-2007 11:01:55
Well, let me re-phrase the problem. When traveling straight, as without grabbing any clutch handles or brake pedals, it tracks fine. This I think is an indication that both clutches are fully engaged and pulling or else the tractor would turn one way or another. Right?
But, when turning by pulling in the left or right clutch it turns one way but not the other. I would assume this indicates one clutch is releasing fine but the other is not. Right?
Hope that is more clear. Thanks.
Randy
jdemaris
09-26-2007 05:31:40
 Re: Allis Chalmers HD-4 Steering Problem in reply to Rudy2, 09-25-2007 21:34:23
And what about the steering brakes? If they work, they are supposed to stop either track regardless if the clutch is working, not working, stuck, etc. If you engage the brake and declutch the track - and the track keeps going and the engine is laboring - then the brake is working and the clutch is stuck. Not any different than if you were in a stick-shift car or truck, held the brakes on and let the clutch pedal up in gear, and pushed the clutch IN while in gear. Letting the clutch up would stall or work the engine if the brake was on and working. With the HD4s, just a little oil on the clutch disks - if they are fiber - is all it takes to make them get "glued" together. The optional bronze disks don't stick as badly. But, as I already stated, early HD4s were prone to breaking the long bolts that hold the clutch packs together. You ought to peek inside and make sure they're not broken. They are supposed to be updated from 5/16" to 3/8".
rudy2
09-26-2007 12:53:23
 Re: Allis Chalmers HD-4 Steering Problem in reply to jdemaris, 09-26-2007 05:31:40
Looks like I need to pull out a clutch as I expected. Sure wish AC didn't bury the access cover under the fuel/hydraulic tanks. At least they come out without tearing down the final drive.
Randy
jdemaris
09-26-2007 13:22:00
 Re: Allis Chalmers HD-4 Steering Problem in reply to rudy2, 09-26-2007 12:53:23
Yeah, but I'm not sure if I'd call it easier - than working on a Deere 350 that requires pulling the finals. I was a Deere mechanic for many years and used to curse their design. But, after doing the steering clutches on my HD4 - I'm not so sure one is any better than the other.
jdemaris
09-25-2007 16:11:28
I don't understand the diagnosis problem. The steering has two functions - brakes and clutches. Staring with the steering clutches - doe either side stop getting power when you pull on its respective steering-clutch lever? And, if you hit a brake pedal for either side, does that side grab? If you decide the clutches are stuck - which is common - chances are you're going to have to pull it apart. Best bet is pull the top cover off and see what things look like inside - e.g. look for rust or oil contamination. Also, look for broken pressure-plate bolts. The older HD4s were prone to bolt breakage until the size got updated from 5/16" to 3/8".
