D7-3t steering clutch control oil
Grayhead
09-28-2007 07:02:52
Good morn to all . can anybody tell me how to change the oil in the steering control system? And does it use oil from the clutch area ?
Or does it have its own resivor.
this is on a D7 3t
Old Magnet
09-28-2007 07:58:00
 Re: D7-3t steering clutch control oil in reply to Grayhead, 09-28-2007 07:02:52
Hi Grayhead,
Has its own reservoir.
Access to drain plug is inside bevel gear compartment after removing rear cover. Uses same as engine crankcase oil. (5-1/2 quarts)
It is also possible to pull old oil out with suction gun down through the hole in the seat tank after removing the suction strainer (big hex plug top/center of unit) but to get it all out the plug removal is the best bet..... .not real handy, especially if there is a winch mounted to the tractor.
