HD11
Udo65
09-30-2007 17:41:56
Purchased the tractor a couple ofd years ago for scrap iron price from a friend and finally last weekend I got around to freeing up the motor. Now I need a gasket set. The engine serial # is 11-11267 and tractor serial # is HD11EC-10930. Anybody know where one is available? I'm not going to do an engine overhaul because there is no ridge ring and the valves all look good. Should a person scarify the cylinders with a fine wet and dry sandpaper? A couple months ago I posted some questions about overhauling a Ford skidder motor. The crank wasw already .040 under and the cam shaft had a lobe missing. Couldn't find a cam shaft and other parts got too expensive so end of story! Thanks beforehand if anybody can help Udo
hector gemme
10-01-2007 03:07:30
 Re: HD11 in reply to Udo65, 09-30-2007 17:41:56
I have many HD11 use parts but no new ead gasket and I have 1 FORD diesel 4 cyl. dismantle for parts ,if I can help you.
bob plumadore
09-30-2007 18:17:20
a better glaze buster is to first cover te crank with grease then plastic, take a towel and soak it in Viniger, wash the cylinder walls with the viniger, let it set over night. rinse with running water
