IH TD-9 steering clutches
Justin Zant
09-30-2007 19:48:16
I am thinking about buying a good running moving IH TD-9 with the Bucyrus Erie(spelling?) dozer blade on it, everything works good but it wont steer. Earlier this summer when it was parked it steered fine, I was just wondering how big of a job it is to get the steering clutches working again. I haven't ever really worked on a dozer before but I'm definitely not afraid to tear into one, was hoping someone on here could give me some insight. Thanks a lot.
ferrell
10-01-2007 09:48:35
 Re: IH TD-9 steering clutches in reply to Justin Zant, 09-30-2007 19:48:16
You, might want to check an see if the steerig clutches are not just rusted. You can tell this by removing to the two clutch housing covers . These are located under the seat they are under the the steering clutch adjusters they are to the right & left of them . If this is the case you, will either see moisture or even mud because there is a drain for them in the bottom of housing .If this so clean out the housing ,fill with mineral spirts an let set for a week or so ,going by every now an then pulling back on them to free them up . I,have even left mineral sprits in them ,start the mechine up with it moving pull the steering clutches back one at a time and back and forth to free them up.When storing or letting set for a peroid of I. have cleaned out the housing ,stopped up the hole an filled them mineral spirts to keep that from happening.
hector gemme
10-01-2007 02:58:50
If he was running this summer maybe he need just break and cluch adjustement and am still have TD9 use parts.
