TD340 hydraulic filter -- 2 types?
Charlie
10-13-2007 09:51:34
I have a TD340A. Came with a hydraulic filter unit consisting of a screen unit with two replaceable round paper units inside (NAPA 1139). Always a pain to clean the gunk off the screen. I know some people use a 1 piece unit, totally replaceable. Bought NAPA 1469, as per Napa book, but it has three problems: nothing to hold it in tight, like the spring mechanism on my old unit, a little thinner, and it has a big hole in the opposite side from the pump tube. Did NAPA give me the wrong one? Can someone give me a number for the one piece unit? Are they really interchangeable? Thanks.
Charlie
10-16-2007 12:44:00
 Final resolution for future reference in reply to Charlie, 10-13-2007 09:51:34
If anyone is ever interested, in order to convert to the one piece filter, which is indeed NAPA 1469 or IH 388084R92, you also need to purchase a "filter relief valve" which you can get new from Case/IH for about $20 or used from Wengers and others. The number is 386121R92. It also holds the filter in place.
Lavoy
10-14-2007 09:18:27
 Re: TD340 hydraulic filter -- 2 types? in reply to Charlie, 10-13-2007 09:51:34
I am doing this from memory which is questionable, but to use the later style paper filter, there is another piece you need to get. We went through this a cuople years ago on my brother's T340, and finally found a local dealer that new what the necessary piece was.
Lavoy
