Still searching for a final drive
Case450
10-14-2007 11:35:07
My final drive on my Case 450 self-destructed. It would be easier to replace the whole unit then rebuild. I'm still not sure as to the exact year of my Case 450. I think it's a "C".
The numbers off the old housing are Final drive: 976033 LH
Final Drive drop housing: A50405
My book (not sure if its correct) shows the Final Drive part number as: 101521LH, 101519 - Which of these numbers is mine?
I don't know what size Gear or spline I.D. I have either.
Can anyone help me identify so I can narrow down my final drive hunt?
Much obliged,
Tom
AJK
10-14-2007 17:06:46
 Re: Still searching for a final drive in reply to Case450, 10-14-2007 11:35:07
There is a Case parts look-up online,its at the link below,when the first page opens click on Click here to begin your search,another page opens,in the top left corner type in 450,several options will appear,scrolll down and click on the first 450,then on figure listing,go down to transmission final drive,when the parts appear in the right panel click on the icon on the right to get a bigger picture,your tractor is a 450 model going by the cover number you quoted.Machinery Trader is a good source for used parts.
AJ
JCSinGA
10-14-2007 12:52:44
Probably not what you're wanting to hear but I needed one about 6 months ago for a straight 450 dozer and was not able to find one, Hotline service couldn't find one either.
On the model I was working on there was a right and left side, loader final drive wouldn't work the output shaft and housing was shorter.
After finally getting thru to them that I was working on a 450 CASE not 450 JD (they sent me a used final for a 450 JD)I wound up buying gears and bearings and rebuilding the one I took off.
Mabye you will have better luck finding one for yours and you may since it's a later model. I probably have not offered and useful advice other than losing 2 weeks of machine time while I was searching for parts.
