Komatsu D21A lift pump
Jeff Oliver
10-15-2007 18:43:30
Where is a good source for a lift pump for this dozer? Ours is starving for fuel and I was told this would more than likely be the fix for it unless someone here has another idea to look at.
thanks!
AJK
10-16-2007 07:38:36
 Re: Komatsu D21A lift pump in reply to Jeff Oliver, 10-15-2007 18:43:30
May not be the lift pump,take the line off at the lift pump from the tank,some of the Komatsu fuel joints that use a banjo fitting often have a gauze filter inside the bolt,when you remove the pipe check the flow as you can have trash in the tank,if your flow is ok to the L/pump and you have clean fuel filters in the lift pump may be at fault,take it to your local fuel injection shop for repair,most of the Jap stuff has injection equipment that is made under licence from Bosch so the shop will be able to help.
AJ
