tracks for a TD340
TCD
10-18-2007 19:25:24
looking for a good set of tracks for a TD340 any help would be great.
CHinNY
10-19-2007 08:25:30
 Re: tracks for a TD340 in reply to TCD, 10-18-2007 19:25:24
I have several sets have one that is 85-90% and i will pin& bush it. But these are not cheap so if you have a fait heart don"t ask. Also have 500 chains still not cheap both of these chains are no longer available. The 500 will work on the 340 as a track group as a 500 has 1/2 bolt holes and a 340 is 7/16. I also have grousers.
Victor Avery
10-19-2007 06:33:32
I can tell from experience that IH500 tracks will work, but make sure if you have a dozer you get IH500 dozer track and vice versa if you have a loader. Dozer tracks are 14 inches wide and loader tracks are 12. Dozer tracks will rub on a loader.
135 Fan
10-19-2007 10:37:47
 Re: tracks for a TD340 in reply to Victor Avery, 10-19-2007 06:33:32
The tracks (rails) are the same for a dozer or loader just the track pads are different. If your pads are still good, check the bolt size. It would be best to have the rails with the same size bolt holes as the pads. If the pads need replacing go with the bigger bolts if the price is about the same. Dave
