CAT D8H
peter82
10-20-2007 10:39:36
Have to bleed air from trans pump after it sits unless you park the front end down hill
AJ.
10-22-2007 07:47:09
 Re: CAT D8H in reply to peter82, 10-20-2007 10:39:36
Sounds like something causing a vacuum,are all the breathers clean,for the pump to go empty air has to be getting into the pump to allow the oil to flow back and that is usually the seal on the input shaft,how is the suction strainer is it clean,as I remember the transmission pump had a pipe that connected to the outlet relief valve of the torque convertor for the purpose of letting air escape on startup,valve could be stuck closed,no harm to clean the suction strainers for both the transmission and the torque convertor as they are often overlooked.
AJ
Bob/Ont
10-20-2007 17:22:08
Reseal the complete trans pump suction line.
Later Bob
