410 JD backhoe won't pull
RIck S
10-21-2007 05:06:25
My dad has a 410 backhoe that has given him numerous problems. He has replaced the clutch discs and the reverser.In the beginning , the back hoe was slow when you shifted from forward to reverse and now it won't pull at all.It did pull for awhile but now has stopped.
CCer
10-21-2007 09:28:15
 Re: 410 JD backhoe won't pull in reply to RIck S, 10-21-2007 05:06:25
Best advice, get a manual. Put a gauge in the bottom rear of the valve on the right side of the transmission. I think it should show about 135 psi, in f-n-r. Check clutch linkage,for adjustment, look for looseness in linkage, missing or partially sheared pin, as pedal also controls pressure.
