Galion Road Grader Stuck clutch
kent boyer
10-24-2007 11:24:58
Hello,
I have a Galion road grader that has a stuck clutch. Does anyone know how to get a cluth to free up? The engine runs and someone told me to hook it to a big tree and let it go. I don't want to tear up the transmission or the axle drives.
I need your suggestions.
Thanks,
DGH
10-25-2007 20:17:23
 Re: Galion Road Grader Stuck clutch in reply to kent boyer, 10-24-2007 11:24:58
Put a load on it in high gear with the clutch disengaged. That puts the load on the clutch not the rearend.
hectorgemme
10-25-2007 08:59:29
I think you just try to greasse the cluch shaft bearing and rod before pull out that cluch and I have a GALION than I use 2 hours a year and it apen me too that cluch was stuck.
tiresntracks
10-24-2007 21:15:30
I don't think I'd tie it to a tree. You might break a drive chain or something else. If you have a place to do it, I'd just push as big a blade-full of dirt as you can, with out spinning the tires, and hold the clutch down.
