one more comment
jim48
10-28-2007 15:56:03
I can't walk away from it, I own it...not one of my smarter moves, but I bought it at an auction. I don't know if it has a wet clutch or not, a friend of mine told me he thought it did..I'm absolutely new to dozers..never drove one until I bought this one, just wanted to clean my farm up with it. HL-R is on the floor, and drive 1234 is on the side. I know it is a 4 cylinder diesel, so that makes it a 450. The numbers on the the motor are T24961. I know I'm confusing you, but I do appreciate your help. If it doesn't have a wet clutch, is it something that can be fixed reasonably...less than $5,000? Thanks again.
jdemaris
10-28-2007 17:31:37
 Re: one more comment in reply to jim48, 10-28-2007 15:56:03
T24961 is the earliest diesel ever used in the 450 or 2510 ag. tractor - it's a 202. Sounds like a 1966 crawler.
The HL-R trans is very rugged - but like anything else, it will wear out - and your's is over 40 years old. Parts for it have gotten incredibly expensive. So, often - when they start to slip - they go to auction. Especially early 450s since they aren't very powerful and not worth as much as the later versions. A late 450B 239 turbo will run circles around an early 450 with a non-turbo 202. Nice thing - for the sellers is - they usually work cold and don't start slipping or not-moving at all until hot. Same with the engine. That engine uses a pair of balancing shafts that often don't get fixed during normal "in-frame" engine rebuilds. When they get worn, and engine has great oil pressure cold - and gradually gets lower as it gets hot - sometimes down to zero at engine-idle. I had a chance to buy a 450 last month - with a winch and a 6-way dozer. The guy wanted $2800 - which normally would be a steal. But, he was also honest and told me that once it's hot - it won't move. I passed it up. Even doing all the work myself I could of spent well over $3000 on the trans - and who knows what else? That would make it a $5800 machine - if I assume all my labor is worth nothing. I'm not trying to make you feel bad - just telling you like it is. I hope you did't pay more than $2000 for it. If so - the only way out - is to send it to auction again - or - take it apart yourself and hope to get lucky.
jim48
10-28-2007 18:42:30
 Re: one more comment in reply to jdemaris, 10-28-2007 17:31:37
Thanks for your help.
