winterizing a TD-6
RodneyR
10-30-2007 21:22:07
Can anyone tell me if I drain the radiator and pull the plug right above the starter on a 1942
TD-6 will I be safe for the winter ?? It usually gets -20 to -30 here in Utah
Thanks Rodney
egoman
11-09-2007 11:36:10
 Re: winterizing a TD-6 in reply to RodneyR, 10-30-2007 21:22:07
Why would you not just add antifreeze to the system . If you drain the unit you stand a real good chance of your water pump seals going out on you . As well you shouldnt be running straight water in the unit as it will promote rust and corrosion.
