oliver ixb3 need crank and bearings
sky bartlett
11-04-2007 12:50:13
I'm looking for a crankshaft and the bearings/bushings for my hercules ixb3 engine in my oc4 crawler. my local carquest can get the cank for $350 which didn't seem bad but they wanted another $400 for the bushings. I'd be happy to at least find some cheper bushings.
Esev
11-07-2007 18:20:52
 Re: oliver ixb3 need crank and bearings in reply to sky bartlett, 11-04-2007 12:50:13
Sky, I have some parts engines here in VT. Problem is they are the older IXK, and I think the bearings are different.
hectorgemme
11-04-2007 17:03:59
I have a complet use motor for $400.00 FOB
sky bartlett
11-04-2007 17:13:14
 Re: oliver ixb3 need crank and bearings in reply to hectorgemme, 11-04-2007 17:03:59
does she run? or will she? How much to ship to me in NH? sounds like a good deal.
hector gemme
11-04-2007 17:31:51
 Re: oliver ixb3 need crank and bearings in reply to sky bartlett, 11-04-2007 17:13:14
I give you a price FOB am not shipping heavy parts and did't start this motor because the carb.and mag ben sold on but he supposed to be good.
sky bartlett
11-04-2007 17:45:13
 Re: oliver ixb3 need crank and bearings in reply to hector gemme, 11-04-2007 17:31:51
where are you? is it something I could pick up?
hectorgemme
11-05-2007 02:21:20
 Re: oliver ixb3 need crank and bearings in reply to sky bartlett, 11-04-2007 17:45:13
I am located in BOUCHERVILLE near MONTREAL CANADA.
jdemaris
11-04-2007 14:29:08
You ought to be able to find an entire engine in that price range ($300). I've passed up many since I already have a few spares. My neighbor has around a dozen, including a few brand new ones. Last year, somebody on Ebay had a bunch of brand new IXB5 engines - bolt-in swap for the IXB3 -and many sold for around $600 each. My neighbor has two.
If its just parts you want, did you try Zimmermans Cletrac in Pennsylvania?
J Schwiebert
11-04-2007 14:18:46
Let me explain this a little bit. Cranks can also probably be found for less money. The key bug a boo are the mains. Neither Clevite or F-M have them as neither one made the thrust bearing. Gould made the thrust for both Clevite & F-M. When Gould got split up the tooling for the mains was lost so to speak. I am going to send you an e-mail with some suggestions. What is the problem with your old crank? J.
sky bartlett
11-04-2007 16:03:04
 Re: oliver ixb3 need crank and bearings in reply to J Schwiebert, 11-04-2007 14:18:46
I was going to have the crank turned but when they magnafuxed it or whatever they call it they found multiple cracks and pronounced it dead
