Moving Disabled Skidloader
Formerly PaMike
11-06-2007 09:20:41
I have a 485 NH skidloader that lost all hydraulic power. Its sitting on the side of a hill. I dont feel comfortable jacking it up or even trying to get it onto a trailer where its at. Is it safe to drag it(its on dirt) a couple hundred feet till its level? Any tips to get a skidloader on the trailer? I have a 65 Hp loader tractor that might be able to push it on...
Marlowe
11-06-2007 19:28:30
 Re: Moving Disabled Skidloader in reply to Formerly PaMike, 11-06-2007 09:20:41
hyd pump spline is striped out
Charlie
11-06-2007 11:55:26
My older Bobcat 610 rolls freely when turned off.
135 Fan
11-07-2007 11:46:47
 Re: Moving Disabled Skidloader in reply to Charlie, 11-06-2007 11:55:26
A 610 isn't hydrostatic. Dave
135 Fan
11-06-2007 10:16:48
It's probably OK to drag it a short distance. Most likely the wheels will just skid. You could check with the manual or a dealer to see if it has a way to disengage the hydrostat. I know some commercial mowers have a button you can push in to allow for towing. Once you get it on level ground, maybe you could jack it up and put some planks under it so it could be slid on the trailer. If you had a few pieces of pipe to put under it, you could roll it a lot easier. You'ld need some pretty strong planks though. Hope this helps. Dave
