MF 220 backhoe
Mark / Wi
11-07-2007 14:32:24
I have a MF 220 backhoe. The boom swings 60 degrees freely left to right. I can move it without resistance by hand. The rotary cylinder has been rebuilt, still have the problem. Any ideas?
Thanks in advance for your comments.
ptbull / bob
12-05-2007 15:33:15
 Re: MF 220 backhoe in reply to Mark / Wi, 11-07-2007 14:32:24
Hi I have what I think is a MF220 backhoe, But the front forks says yale?? every where I look all I find is Massey ferguson does any one have a picture of the mf220 backhoe? I am trying to get a parts manual for what I have and wish to get the proper book.
Homer from Pearl
11-10-2007 22:56:24
Mark,who rebuilt the rotary swing valve? Unhook the oil lines at the rotary cylinder, lift the boom off the ground and now hand push the boom left and right.Does oil instantly come from the cylinder ports? It should.If not, as someone else said it may still have air in the rotary cylinder.Hook lines back to rotary cylinder.Now crack the 2 lines coming out of the swing lever valve.Crank engine and operate swing lever left and right.Is oil coming out of the valve lines? This will give us a little more info to work with.Thanks, Homer
Mark / Wi
11-08-2007 08:51:44
Chuck the seat should move with the boom left to right. On mine the seat moves as would be expected but the boom doesn't until the seat is about 30 degrees out of line with the boom , than it pulls the boom along with it.
chuck bergstrom
11-07-2007 15:35:43
Mark, Tried to find the answer in the service manual but unsure.
Have you used it enough to purge the air out of
the system? Also is the fluid level high enough
so it isn't cavitating? Good luck, Chuck
