JCB 1600B Backhoe fuel problem
micahw
11-08-2007 15:52:22
I have a 1600B with the turbo perkins. It will run for about 5-30 mins then sputter and die. I bleed the system and it does the same thing again. Please help
AJ.
11-09-2007 00:09:45
 Re: JCB 1600B Backhoe fuel problem in reply to micahw, 11-08-2007 15:52:22
Service the fuel system,take the top off the priming pump and you will find a gauze filter underneath,clean the gauze and the body of the pump,there should be a good flow of fuel at the priming pump so you will need to have hose clamp on the line to stem the flow,if you do not have a good flow there is a blockage in the outlet from the tank,clear it,fit a new fuel filter/s and bleed the system,first open the bleeder screw on top of the filter/s,prime the lift pump till air free fuel comes through,close the bleeder/s,open the two bleed screws on the injector pump,prime till clear fuel comes from the bottom nipple,close it and finish by doing the top one,open all four injector pipes a couple of turns and spin the engine over on the starter till fuel spurts out,tighten the pipes and start the engine,you should be ok.
AJ
