case 550g
doubled
11-08-2007 17:30:36
leaking 6 way blade control valve,used machine someone must have disassembled then failed to get it back together correct,does anyone know if the individual valve bodies are seal with o rings between each valve,also leaking around bottom caps and top spool plates. About how much for a kit to rebuild?
JFoshee
11-10-2007 10:16:17
 Re: case 550g in reply to doubled, 11-08-2007 17:30:36
A.J. is correct, there are O-Rings between the sections and I believe the spools are sealed with a teflon seal ring. Top and bottom. If memory serves me there is no "kit" each part has to be purchased seprately, but I don't think they should be very expensive. The Case parts website is great. I find all my own parts, print out a list, then take it to my dealer.
doubled
11-12-2007 19:44:14
 Re: case 550g in reply to JFoshee, 11-10-2007 10:16:17
Thanks for the advice,this will be a good winter project. d.d.
AJ.
11-09-2007 13:19:55
There are O'rings between the sections, go to the link below for to access the Case online parts lookup.
AJ
