FiatAllis 11B Idler slide bars
jkloepping
11-13-2007 22:25:41
I had to replace an idler, and I noticed that the "slide bars", which are the sacrificial bars bolted on the frame upon which the idler slides, are pretty worn. Minnpar wants 700 for new!@$# so I was thinking of fabricating some. It seems that mild steel would be okay for this application, after all I want the bars to wear before the idler. What do you all think, or does anyone out there have a source for the bars?
135 Fan
11-14-2007 14:42:08
 Re: FiatAllis 11B Idler slide bars in reply to jkloepping, 11-13-2007 22:25:41
You could build it up with hard facing and grind it smooth. Dave
AJ.
11-14-2007 01:05:24
At my place we use cutting edge material of the right thickness for building up the guides,it highly wear resistant and welds on well,mild steel will squash,but I suppose you can do it a few times for $700.
AJ
