Dozer D6 9U dry clutch
Joes13
11-17-2007 19:15:55
I have a Dozer D6 9U, I have some troubles with the clutch, it is a dry clutch but it is too hard to engage also it is too hard to release it, it is not having enough presure to stop the transmition to place the speeds.
Some can give me a hand?
Joe
Bob/Ont
11-17-2007 19:45:32
 Re: Dozer D6 9U dry clutch in reply to Joes13, 11-17-2007 19:15:55
Joe, it should take about 30 Lb to pull the clutch in and push it out. Take apart the linkage and lube it up may help. It's an "over center" clutch. There should be a clutch brake that works on a drum infront of the driveshaft to stop the trans for shifting. Have a look and come on back.
Later Bob
Joes13
11-18-2007 04:34:27
 Re: Dozer D6 9U dry clutch in reply to Bob/Ont, 11-17-2007 19:45:32
there is a plate that friction against other plate to stop the transmition when I engage the clutch, is it the brake that you mention?
Or where is located the drum?
That is the problem that I can not stop the transmition to shifting,
Joe
Old Magnet
11-18-2007 08:16:45
 Re: Dozer D6 9U dry clutch in reply to Joes13, 11-18-2007 04:34:27
It's the oil clutch that has the drum style brake.
The dry clutch uses the old style collar and plate type brake. Adjusting the main clutch should bring in the brake adjustment unless the friction surface (replaceable) on the plate are shot. There is no separate adjustment for the brake only.
The main clutch is adjusted by loosening the hub clamping bolt and turning the assembly in or out with the transmission in gear until you get the right snap over action.
