Coolant Leak 951 Crawler
RCP
11-18-2007 04:29:12
The old crawler has developed a pretty good leak near the front of the engine. After looking at the parts manual, it seems that it might be a "doughnut" between the head and the front cover. Can this seal be replace without removing the head? What is the correct procedure? Do these seals go bad over time, or is there another issue we need to address?
Thanks
Rich
Dave Neubert
11-22-2007 14:15:16
 Re: Coolant Leak 951 Crawler in reply to RCP, 11-18-2007 04:29:12
When you replace the the rubber seal be sure to check the ferrule that fitts inside the seal most of them are plastic and if the engine has run hot it deforms the ferrule.
Bob/Ont
11-19-2007 06:24:30
The 931 with a 3204 engine has something like that. It's a ring of rubber with a pipe inside and a hose clamp on the outside. If that is what you have, just loosen the clamp and lift it out. Drop in a new one and tighten clamp to expand it tight.
Later Bob
RCP
11-19-2007 08:53:00
 Re: Coolant Leak 951 Crawler in reply to Bob/Ont, 11-19-2007 06:24:30
Bob
Thanks for the insight, I probably have the model number wrong but as you say it is a Cat 3204 engine. I will take another look, it is at my brother"s farm.
135 Fan
11-20-2007 10:47:17
 Re: Coolant Leak 951 Crawler in reply to RCP, 11-19-2007 08:53:00
There's a big difference between a 951 and a 931. I know exactly what Bob is talking about. On my 931B, I thought it was kind of a hokey set up but it works. I remember talking to the mechanic about it because it looked like a wierd place for a hose clamp. Dave
AJ.
11-18-2007 14:38:32
What 951 have you got,A,K,J or H series,three different engines.
AJ
