FD-14E Dozer
shatski
11-23-2007 14:24:00
Need to replace the oil pump on my FD-14E. How much of a job is this going to be...?
Roy Suomi
11-23-2007 19:40:25
 Re: FD-14E Dozer in reply to shatski, 11-23-2007 14:24:00
What indications do you have that the oil pump is at fault ?? Low oil pressure can be caused by several different problems..Such as ;Excessive bearing clearances, Faulty or stuck oil pressure relief valve, Oil pump clearances too large to make oil pressure , and finally a broken crankshaft [ seen this on a Ford 361 truck engine and a Deere 690-B excavator]...
shatski
11-23-2007 14:25:06
Should add that it is an engine oil pump I need to replace..
