final drive right side for TD9 dozer
jerry thomas
11-24-2007 20:31:21
i have a td9 international dozer, will sell or buy parts
daveleeander
12-03-2007 05:27:34
 Re: final drive right side for TD9 dozer in reply to Andrew Mawson, 11-24-2007 20:31:21
Jerry,
If you are talking abut the shaft that goes from one final drive to the other, that is called the swivel shaft, and it is one piece. If it is bent, you're in for a job my friend to replace it. I don't know whether you can straighten it or not, but it has to be straight, and not weakened.
Dave
bcPA
11-25-2007 18:03:39
 Re: final drive right side for TD9 dozer in reply to jerry thomas, 11-24-2007 20:31:21
call me 570 636 1976 thanks
hector gemme
11-25-2007 15:11:22
I have some use td9 parts.
jerry thomas
11-26-2007 19:18:50
 Re: final drive right side for TD9 dozer in reply to hector gemme, 11-25-2007 15:11:22
if you have a replacement final drive what is your price for it.
hectorgemme
11-27-2007 03:00:40
 Re: final drive right side for TD9 dozer in reply to jerry thomas, 11-26-2007 19:18:50
I have some final drive parts but need to know the parts you need,pinion,gear and carrier,housing inner or outer and need part number.
jerry thomas
11-28-2007 04:31:19
 Re: final drive right side for TD9 dozer in reply to hectorgemme, 11-27-2007 03:00:40
thanks for the reply, the casting # is 8513. i might buy the entire assy. if the price is right. everything may or not be bad. the shaft got bent that goes through to the other drive is bent too. does it seperate in the middle wher the block that looks like a weight is? my phone number is 936 642-0732 i`m in texas
jerry thomas
11-28-2007 04:31:15
