Not a 3-71 it's a 3-53
Thomas R. Spiva
11-27-2007 17:35:09
Had a brain cell short out, anyway, my Detroit Diesel 3-53 still won't shut down.
It's a late 50s early 60s model.
Anyone have a manual for this thing?
Thomas R. Spivak
12-01-2007 13:20:32
 Shuting down 3-53 in reply to Thomas R. Spivak, 11-27-2007 17:35:09
Fixed the the shut down problem today. As Jerry sugjested, there was a broken pin on the shut down lever inside the governor that pushes the throttle down past the lowest idle and basically stalls the engine,from what I can tell this took care of it and all is OK now. Thanks to everyone for their input.
jdemaris
11-28-2007 08:37:04
 Re: Not a 3-71 it's a 3-53 in reply to Thomas R. Spivak, 11-27-2007 17:35:09
Yeah, I have 3-53 manuals. I've got two backhoes with 3-53s. What do you want to know?
Thomas R. Spivak
11-28-2007 15:20:37
 Re: Not a 3-71 it's a 3-53 in reply to jdemaris, 11-28-2007 08:37:04
I need details on Governor, I can't get this thing to shut down unless I use the blower shut off. The gov. lever was stuck when I got it so I took the idle screw out and sprayed WD 40 in the hole and slowly worked the lever back and forth until it moved full range, but it still won't shut down. Idle is set to as low as possible and still keep it running. Engine runs perfect otherwise.
local puller
11-28-2007 03:51:22
This very simple. Its probably the cable adjustment. Go to the governor housing ,remove the regular kill cable, not the emergancy cable , start engine ,try to kill manually at the gov housing, if it works, the cable is out of adjustment, if it dont it probably the rack, injector adjustment.
135 Fan
11-27-2007 19:33:39
I knew a guy that had 6-53's in his excavators and they had an emergency only shut off cable that was basically a positive air shut off. There must be something that isn't letting the fuel shut off at the injection pump. Dave
Thomas R. Spivak
11-28-2007 05:36:39
 Re: Not a 3-71 it's a 3-53 in reply to 135 Fan, 11-27-2007 19:33:39
The shut off is on the governor not the injector pump, next to the throttle lever.
It has no cable on it at the moment and if moved through it's full range, it does nothing.
